How can I put a door inside a frame? The two pieces are meant to fit together perfectly, but I can't align it with the move command.
The door (the one with crossbeams) fits in to the side of the main body. Is there a command for this?
Design attached
Solved by g-andresen. Go to Solution.
Please allow Download.
or
File > save as f3d on local drive > attach to next post
günther
In a previous thread you needed the doors cut from the frame,
roll the time line back, to before the move, or
if you are using Components, use Joint to put them in place.
Might help.....
