Hello everyone.
I want to model the object shown in the image correctly, I just created it with the help of 3 separate sketches, how I construct it correctly.
Solved by g-andresen. Go to Solution.
Solved by whittakerdw. Go to Solution.
I cleaned it up a bit, I am not sure if this is what you were looking for or not. If not, please let me know and we may can rework this. I have one file how you had it that was cleaned up, and I have another where I filleted the edges with a 1 mm fillet to clean it up and join the parts a little better.
Ok, looks good, I understand there is no other way but to create some drawings ...
I really thank you.
After I looked at it more, the middle bar wasn't centered at both ends so I corrected that. I filleted one with as large of fillets as it would accept to allow as smooth of a transition between parts as I could. Again I also have one that doesn't have fillets in case you weren't intending on having fillets.
Wow great idea, you really helped me .....
Thank you so much for your time and thought.
