Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How to model a curved arm
9 REPLIES 9
Message 1 of 10
maorbiton9654
281 Views, 9 Replies
Hello everyone.
I want to model the object shown in the image correctly, I just created it with the help of 3 separate sketches, how I construct it correctly.
9 REPLIES 9
Message 2 of 10
aliobidi
in reply to: maorbiton9654
Hi ,
we didn't know what is your goal
Message 3 of 10
maorbiton9654
in reply to: aliobidi
The goal is to build the solid correctly in a geometric sense, you can see that the geometry is very distorted in my working method.
Message 4 of 10
g-andresen
Should the arm be rigid or movable (with joints)?
günther
Message 5 of 10
maorbiton9654
in reply to: g-andresen
Rigid
Message 6 of 10
whittakerdw
I cleaned it up a bit, I am not sure if this is what you were looking for or not. If not, please let me know and we may can rework this. I have one file how you had it that was cleaned up, and I have another where I filleted the edges with a 1 mm fillet to clean it up and join the parts a little better.
Message 7 of 10
Ok, looks good, I understand there is no other way but to create some drawings ...
I really thank you.
Message 8 of 10
whittakerdw
in reply to: whittakerdw
After I looked at it more, the middle bar wasn't centered at both ends so I corrected that. I filleted one with as large of fillets as it would accept to allow as smooth of a transition between parts as I could. Again I also have one that doesn't have fillets in case you weren't intending on having fillets.
Message 9 of 10
g-andresen
have a look at this
günther
Message 10 of 10
Wow great idea, you really helped me .....
Thank you so much for your time and thought.
