I am trying to constraint to a certain line that does not exist on my geometry. So in order to constraint to that line I set up a construction line on the surface of the geometry. Now I am trying to constraint a new sketch to the construction line but I am not able to select the construction line for any constraints.
What am I doing wrong? What are the construction lines used for if I cannot use them for constraints?
Solved by HughesTooling. Go to Solution.
Looks like you need to press P and project it into the active sketch.
Mark
Mark Hughes
Owner, Hughes Tooling
Looking at the timeline you created an Axis not a construction line.
Mark
Mark Hughes
You are correct. My bad, I am rather new to Fusion 360. The solution above is working for me.
