Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How do I close this open mesh?
2 REPLIES 2
8069 Views, 2 Replies
So I have to close this mesh in a way that it keeps its form. The C-shape is meant to fit around another object, so it's C-shape must be preserved. It literally just needs to be a flat patch along the open edge to maintain it's profile. This is for 3D printing so if there's a better/easier way, please lmk. I've been trying to close it, but I don't have very much experience and I haven't been able to find helpful instructions to do what I need. Please help! (File attached)
2 REPLIES 2
TheCADWhisperer
For geometry this simple - I think I would remodel it from scratch.
Should only take about 10 minutes and the results will be much better.
mavigogun
in reply to: TheCADWhisperer
I suppose that depends on Ryan's capacity to easily locate critical geometry- the profile of that open mouth, 'back side' surfaces that must conform/not conflict with a related part.    That said, supplied geometry in the STL is likely faceted to the point of useless- I very much doubt the matching part relates closely to that shape.
That said, find attached a possible workflow were you to import a higher resolution Mesh; using the crude supplied part-
