Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Selected Joint Type Will Result In Conflict Issue
2 REPLIES 2
3315 Views, 2 Replies
I am new to Fusion 360 and have an issue I cannot solve. I am doing a drawing of a TV Tray Table and when adding the joints for the legs I get an error on the last joint that I am trying to draw telling me the joint will result in a conflict. I am unsure what could be wrong and also unsure how to diagnose the problem. Could someone take a look at my drawing and let me know where I have gone wrong? Also, if you could explain how you figured out what the problem is I would greatly appreciate it.
I am assuming it is something small that I am just missing. Drives me crazy when I cannot figure it out.
Here is the link to my file: https://a360.co/2Qz27dR
-Frank
2 REPLIES 2
jeff_strater
OK, no one picked up this one, so I gave it a shot...  This model is deceptively complex.  I was able to add all the joints, without getting a conflict, but I used a slightly different joint scheme than you did.  See the screencast below.  I can get most of the motion that you are after with this scheme, and no conflicts.  My model is attached.  Hopefully this clears things up a little bit.
screencast:
Jeff Strater
Engineering Director
in reply to: jeff_strater
Hi Jeff,
I wanted to thank you for working on my issue.
After playing around with my drawing I was finally able to make it work. I don't know why, but when I changed the order that I was adding the joints to the drawing the error went away. Not sure why that would make a difference.
Thanks again for your time.
-Frank
