3D CURVE TO 2D CURVE LOFT
chadjazwinski
chadjazwinski
I cant figure out how to get a surface connecting the two tops of the model.  been looking and trying thing on youtube and no luck at all....door issue.GIF
laughingcreek
Is this the type of thing your talking about?  Here I copied the faces with the "offset" tool set to a zero offset so there would be edges for the loft.  You could also delete the interior faces to expose those edges also. This is a work around.  It should work by to just select the interior faces as profiles, but doesn't for some reason.  couldn't get the loft tool to think of those as a single continuous path.  There are lots of little weird edges in there for some reason.
