Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
3D CURVE TO 2D CURVE LOFT
1 REPLY 1
chadjazwinski
386 Views, 1 Reply
I cant figure out how to get a surface connecting the two tops of the model.  been looking and trying thing on youtube and no luck at all....door issue.GIF
1 REPLY 1
Is this the type of thing your talking about?  Here I copied the faces with the "offset" tool set to a zero offset so there would be edges for the loft.  You could also delete the interior faces to expose those edges also. This is a work around.  It should work by to just select the interior faces as profiles, but doesn't for some reason.  couldn't get the loft tool to think of those as a single continuous path.  There are lots of little weird edges in there for some reason.
Technology Administrators
