Attempting to import a Revit exported SAT file with all components but Topography turned off I get the Formit error "unable to read the file, failure, no reason given". Any suggestions for importing Revit topography into Formit?
That is the problem with Revit Toposurfaces... you cannot really export them to anything! We did a FormIt Friday webinar on topography topics a few months back. How familiar with Dynamo are you? I included a dynamo script that takes the points from the toposurface, creates a surface, and then exports the resulting mesh to SAT, which can then be imported into FormIt: https://autodesk.box.com/s/x1gn0pnhp5h7em5hlk501gxwo4x0yh6a
hope this helps!
Hi the link for the Dynamo script to convert Revit Topo to an SATT format for inport into FormIt is broken. Any chance you would be willing to repost?
Sure - the links from the original blog post still work - https://formit.autodesk.com/blog/post/working-with-topography
Here's the specific DYN file you're looking for https://autodesk.app.box.com/s/x1gn0pnhp5h7em5hlk501gxwo4x0yh6a
Thanks!
Tobias
Hi Caroline - Thanks for the heads up about the DYN - I can review this weekend and see why it's not working - can you let me know what version of Revit and Dynamo you're using? There may also be a specific dynamo package necessary to have installed. Note that this is the blog post that taught me how to write the dynamo script to convert topo to a surface then export to SAT - you can try recreating from scratch! http://plevit1.blogspot.com/2015/02/dealing-withtopography-in-dynamo.html
Given your situation - I think that modeling the topo in Revit, then exporting SAT to FormIt is the best bet. I doubt you'll be able to do much editing of the topo in FormIt - but it will be editable geometry. You won't be able to import those changes BACK into Revit later - so you'll have to update your original topo in Revit as well.
Flux has recently announced the shut down of their services (end of March), so I'm not surprised they aren't accepting new customers. Unfortunately that means the end of the very excellent 'site extractor' service!
Feel free to follow up with more 'transition to FormIt' questions. Happy to help,
Tobias
Hi Tobias,
the dyn link is not working. Could you resend or fix the broken link? Sometimes it is embarrassing trying to implement Formit and having to deal with a lot of things to do yet. However, I would appreciate if you could relink. Thanks.
I'm sorry, Maurilio - We (Autodesk) have recently migrated our file storage solution. So these links are broken.
We will update the links soon (now that you point this out!) and update this thread when they are available.
In the meantime you can still revisit the referenced blog post for parts of this content
http://plevit1.blogspot.com/2015/02/dealing-withtopography-in-dynamo.html%C2%A0
Thanks for posting,
Tobias
Hi all,
I will just start with the fact that I am a total newbie at Dynamo, and this is my first attempt in working with it.
I have been also trying to import my Revit topo to Formit using the script provided in this thread, but am experiencing errors left and right. The latest error that I have hit a wall with is:
“PolySurface.ByJoinedSurfaces operation failed.
Unable to stitch Surfaces into a single PolySurface. : ACIS_EXCEPTION_ACCESS_VIOLATION – Access violation”.
I have attached an image of the script and where the errors are occurring. If anyone has a solution (and one that a beginner like me can easily follow) or if someone has a better script or method (sans Dynamo) to get topo into Formit I am all ears!
Thank you
