I was working on some quick wind studies today and noticed an issue with how Forma exports the wind analysis graphics. I had deliberately adjusted my slider to show the results of a 15 mph wind and I placed an inspection point to show the wind speed, as shown below.
When I exported the view with graphics enabled, I noticed that the slider has been reset to the default value, around 10 mph, but the visual wind speed map had remained showing the 15 mph results. This is miss leading because anyone who looks at this will assume the speed indicated at the inspection point represents conditions at 10mph, not 15. Below is the exported graphic still showing the 15mph color map but the incorrect wind speed.
this seems like a minor bug and an easy fix. could the Forma Development team please take a look at this issue?
Solved by eklingerHFVZ3. Go to Solution.
Solved by tord.ekern. Go to Solution.
Hi, thanks for letting us know! This issue should be fixed now (you may have to restart your browser or clear cached files to get the update immediately).
Tord
