Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Visual bug - housing tool
2 REPLIES 2
oduijl
527 Views, 2 Replies
oduijl
Good morning,
While using the housing tool, I encountered a bug regarding the visualization of the buildings in Forma.
As seen in screenshots 1, the house appears to be separated from the bounding box. Yet, when I use the sun analysis tool (screenshot 2), the house is in the right position. So the bug only appears to be visual. It occours when I draw a single house, or multiple on line.
I’ve already restarted Forma and the project, created multiple different versions of the house, yet the bug remains.
I would like to hear if there is a solution for this bug.
Kind regards,
Oscar den Uijl
Aveco de Bondt
Good morning,
Kind regards,
Oscar den Uijl
Aveco de Bondt
Labels (2)
2 REPLIES 2
MartinHallenADSK
in reply to: oduijl
MartinHallenADSK
Hi Oscar!
You are correct, thanks for letting us know! There was introduced a bug on Friday where houses with non-default gable/ridge directions would visualize wrongly. I have deployed a fix and the problem should be resolved now. You would need to refresh the site before the fix takes effect.
Sorry for any inconveniences this has caused you!
Kind regards
Martin Hallén
Martin Hallén
Software Engineer
Hi Oscar!
Kind regards
Martin Hallén
Martin Hallén
Software Engineer
oduijl
in reply to: oduijl
oduijl
Thank you so much for the quick response, the bug is indeed fixed!
Kind regards,
Oscar den Uijl
Aveco de Bondt
Kind regards,
Oscar den Uijl
Aveco de Bondt
