I am trying to push layers from a Rhino 7 model into a project in Forma. I have successfully been able to do this in the past, but today when I am trying to push a layer, the Rhino file will crash when I select the layer in the Forma dialog box. Are there any tips to try to avoid the crash?
The model in Rhino was created by pulling Revit geometry using Rhino.Inside plug in out of Revit, into a Rhino block and then trying to push the Rhino to Forma. I am doing this as a workaround for a mismatched site location between Revit and Forma and the limitations of one proposal per Revit model.
Can you share with us the URL of the proposal that is showing the error in Forma? If you don't want to share it here in the forum, you can contact us through the Help button in the lower right of the Forma window. Select "Contact Support". Please include the URL of this post in your message so we can associate them.
