when working in revit, I want to change the Project North. However, I get the warning "You have moved the Revit group 'Untitled base' that corresponds for Forma. As a result of this change, all elements will be converted to meshes in Forma Upon update." Will this overwrite the "Base" elements in Forma, which are not part of the Proposed option when I update the Revit model back to Forma?
