Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Project north warning
1 REPLY 1
erin.holdenriedSRA7W
209 Views, 1 Reply
when working in revit, I want to change the Project North.  However, I get the warning "You have moved the Revit group 'Untitled base' that corresponds for Forma.  As a result of this change, all elements will be converted to meshes in Forma Upon update."  Will this overwrite the "Base" elements in Forma, which are not part of the Proposed option when I update the Revit model back to Forma?
Labels (1)
1 REPLY 1
We haven't tested with changing the Project North after loading a proposal, but it does sound like Revit is changing the base geometry.  That would result in the base elements changing if it's true.  We will try this out to see if there is an actual change, or if this is a spurious warning.
Forma Design Contest
