Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Incorrect Import Preview Location
3 REPLIES 3
kevin_fielding
336 Views, 3 Replies
When importing geometry into Forma from an IFC which contains shared coordinates aligned with the OSGB Coordinate System. The preview is incorrect.
You can see in the screenshot that the buildings overlap the roads.
The geometry does import correctly however without any modification.
Please can this be resolved. We rely on the preview to validate the import, if it can't be trusted it's mostly useless.
Kevin
Labels (2)
3 REPLIES 3
Hi there Kevin!
I’m from the Team in Forma working on importing files. This is an unfortunate bug that we would like to fix. To fix the problem, we need some data to reproduce the bug. Would it be possible to receive a file and a project location where this occurs? Alternatively, get access to you project with the url from the chrome address bar?
If so, please sent it to me. My email address is under private messages in the right upper corner.
has this issue been resolved?
I'm having a similar geo-location issue where the Forma layout doesn't match the location of our project
This was thought to be resolved. If however you're experiencing problems @brian.diamond89FTD, then it's probably not correct resolved yet. Could you share a bit more information about what issues you are experiencing? Screenshots are always very helpful!
If the project/data is confidential, please DM me on this site, and we can continue from there.
Forma Design Contest
