can I convert back the basic building to line building?
ehsan_omidHTLEZ
ehsan_omidHTLEZ
In building automation, I can release my line building to basic building. After modification can I convert it back to line building?
espen.k.w.wold
Hi, and thanks for reaching out!
After you have modified the Basic Building, it may no longer fit the structure of a Line Building. For this reason, releasing a Line Building into a Basic Building is strictly a one-way process.
The action of releasing, however, is part of the undo-redo stack, so as long as you are in the same session you can undo the release action with crtl/cmd-z if you release a Line Building by mistake.
Hope this helps!
Espen
daniel.silva.gameiro
Hi @ehsan_omidHTLEZ,
Is the issue solved?
