Since forma does not provide high quality elevation terrain maps, satellite photography and lod1 building models , property borders, in my country (Belgium). I would love to be able to import that data which is publicly available from the government web service.
Are there any plans to implement that to forma? I can do that in Infraworks and it works like a charm but my work is more suitable to forma and I have no possibility to utilize any of the data I have.
Kindest regards,
Solved by kristoffer.dyrkorn. Go to Solution.
Good afternoon,
This is not an answer to all your problems, but I do have a workaround for the building data perhaps. In the Netherlands, the building data is provided through Forma (until LOD 1). But sometimes I want to include a higher level of detail. In that case I use Google SketchUp to convert the downloaded data to a .obj file to import in Forma.
Hope this helps a bit!
Kind regards,
Oscar den Uijl
Hi!
We strive to offer third-party free/open high-quality data inside Forma for as many regions as possible - but we also have to prioritize what we support since there are a lot of potential data sources around the world.
As you mention, importing data yourself can be a good alternative. We plan on improving the supported data formats / data types but we can unfortunately not share the exact scope and timeline for that work now.
Best regards,
Kristoffer
Autodesk Forma
