1. Please add manual changing of transmittal status. Draft, Sent, Received, Void
2. Transmittals should be able to be revised, and new files added. Revisions tracking would also be essential, similar to reviews or submittals.
3. Transmittals should be able to be "Drafted" so that files and distribution could be built up over a period of time, not just the moment it needs to be sent.
4. Add an "indicator" in the files view so that you can see which version of each file was attached to a transmittal, similar to packages.
5. Please add a way to reference Transmittals the same way you can reference files, issues, submittals etc.
6. We need the ability to enforce a Transmittal numbering scheme. We also need an additional field for grouping by type. Perhaps custom fields could even be added?
7. It would be nice to have access to the Reviews and Transmittal tools within the Build module view. In general, it would be nice if Build had the option to turn on or off the tools that are only in Data Management view on a project specific basis, so that we don't need to switch back and forth when using said tools.
This is an expansion on another request I made: https://forums.autodesk.com/t5/forma-for-construction-ideas/adding-approval-reviews-amp-transmittals...
