Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Multiple Specifications
Our project has nine (9) Specification books, but because they share the same Spec Numbers, not all can be uploaded into the Specifications tool. As a result, eight of the nine are stored in the Files tool instead of being centralized in Specifications tool. The request is for functionality similar to Sheets' collections, allowing separate specification collections so different spec sets can coexist without conflict. The current workaround requires splitting each page into individual PDFs and uploading them separately, which is inefficient and difficult to manage.
15 Comments
lleindecker
In ACC build "sheets" there is the option to make collections. This same option does not apply to specifications, it would be nice to have collections for specifications so they could correspond to a collection of sheets.
Zach_Jarvies
On my current project, we have two separate spec books. Those two separate spec books share multiple CSI codes, so when we try to upload both spec books, they over-write one another. I know in my company there are several projects with multiple spec books who are running into the same issue. It would be extremely helpful to have a "Collections" tab or something similar to what the Sheets tool has that would allow us to upload multiple spec books without mixing them up.
randi_schieber
This is a need! Having a function similar to how Collections functions for Sheets is essential.
SteveBennettTD
Build> Sheets allows us to create 'Collections', which is great for projects that have multiple Increments (Inc) or Packages (Pkg) submitted to the Authority Having Jurisdiction (AHJ). For Healthcare projects, due to complexity (or other similarly complex project types), they are often split up into multiple Inc. When you go to Build> Specifications, you can only have one Spec current at a time. This means we need to have 'Version Sets' uploaded for each spec since there is one spec per Inc. Then when revised specs are uploaded during construction, those also need a Version Set. So the Version set history gets complicated/messy and challenging to navigate, plus it makes the AI assistant useless. If there was a similar feature for Specs that allowed us to have 'Collections' like we do in Sheets, it would make things so much easier and sensible.
jwhite
Currently there is no way to separate drawing sets/spec books in either of these modules.
We need collections, as in Sheets, to organize/differentiate between sets of documents.
Tags (3)
arumler
Seconding this. We have multiple design packages with specs that are totally different but have the same section number. We don't want them to supersede each other. The collections feature similar to sheets would solve the problem.
sharon_mPRHMT
I have the same problem with my project, I will have 6 different Specification Sets for each Design Package.  A collection for Specifications would really help with this problem.  Loading each Design Package up as  separate "Version" is not a solution as you can't update previous versions when a new design revision is sent out.  Please create COLLECTIONS for Specifications and also allow Tagging like on Sheets.
dsantos6M8FZ
Adding the Collections solution would be helpful to address this scenario, which will occur in many projects.  Please also consider how this data would then flow into the Submittal Log Generation tool to push to the Submittals module.  Our team will need to use our legacy Autospecs tool and do a spreadsheet import as a workaround.
andrew_grillo
Observer
Larger projects like the one I'm on have multiple engineers and specification books, and they often have overlapping specification numbers. Having a feature to allow separating the different books into collections like with sheets would greatly help organization and keep scopes clearly delineated. Currently, the specification with the latest date would overwrite the previous specification, even if they are for different things.
Tags (3)
alycia_alves4GFWV
Same issue on almost half of our jobs! We uploaded them all to the specs tool, but the sub needs to know to filter by the specific spec section version for the increment they are working on. Would also like to be able to have multiple spec versions in AutoSpecs!
ebethfoster
Right now you can create multiple Version Sets in Specifications, but you still have to give your specifications different Codes, even if they are the same specification section, but for a different Version Set. For example, if have a project that includes building a Warehouse (Specification Version Set 1), and a Control Room, Specification Version Set 2), each of those buildings has a Spec Book that uses the same numbering scheme (CSI MasterFormat), but the specifications are different for each building. Right now, if you Add a second version set, the add a specification for that version set, each of the Specs with the same Code are added as a 2nd version (revision) in the first Spec Version Set, instead of being added into the new, different Version Set. That does not make sense. What is the point of having different Version Sets? It's not for revisions of the same specifications.
jonminick
A duplicate idea was merged into this one. Its votes and comments now count here, so please keep voting on this idea.
jonminick
Thanks to everyone who has voted and shared feedback here. The product team is reviewing this idea now, and we'll keep its status current as it moves along.
jonminick
Status changed to: Accepted
Thank you all for the votes and feedback on this one. The product team has accepted this idea into its backlog. We don't have prioritization details to share yet, but we'll keep this thread updated as it progresses.
SteveBennettTD
Huzzah! Thank you!!!!
