Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Add Members By Company
At my firm, we tend to have everyone in the company on each project. This can be a pain when we get a new hire and I have to add them to each project. It would be easier if they were just automatically added when I add them to the company rather than me having to go to each project and add their email one by one. We do this because we often have coworkers who will help on any project if someone is out, and I can't limit the projects to only the people working on them. It wouldn't work at my firm.
UPDATE:
It seems as though when you add a person to a project template it will add them to every project made with that template. I don't recall it being like this in BIM360, so I think my old habits carried over to the new platform.
I brought my old template out of the archive, making sure it wasn't published. This way I can add my new employees on the back end of all my projects.
22 Comments
Chad-Smith
We face a similar limitation.
We don't need every employee on every project, but we do need an easier method to assign our Company to the permissions in our ACC project Template.
Ryan_Holland_LDP
We assign certain internal users to a project template, so when a new project is created these users are automatically added. This works well for us, and we know that the core list of 10 members have access to every project.
aluster
A simple method for adding a user or users to multiple projects would be very beneficial. @Ryan_Holland_LDP What happens when you have a new hire? We just brought someone onto our team two weeks ago and we have a list of roughly 300 projects.
lance.borst
Hi Ava,
We are taking this into consideration. Would you like to see an option window that shows all your active projects (and you select the appropriate) for new hires to be added to? Can you elaborate on your you perceive this functionality integrated into Build?
Ryan_Holland_LDP
Hi @lance.borst
I think in Account Admin it would be good when selecting on a member, in the panel that opens up on the right hand side, a way of first of all seeing which projects they are already assigned to (currently no way of seeing this info without opening up each project), but then in the panel would be a checklist of all projects and which ones they’re assigned to.
Ryan_Holland_LDP
@aluster
yes fair point, my solution before was adding members to a new project. Adding a member to existing projects is a headache and we have the same problem as you.
brucegund
Adding Members in a Template Project works good. But today it stopped working. Now have to add 40 some members manually. On three projects....What a waste of time! Adding members to a project from the Account needs to be better.
floretti
@lance.borst
I work in retail and we'll start using ACC for all of our stores (1000+). Each store will be one project. We work with internal and outsourced teams and I already set them up as Companies. Everybody will get access to all projects.
After a few tests and lots of research I noticed that, despite creating a project template, I can't use Companies to add the users to it. I have to add them one by one. Also, if we have a new team member join us, I can't see a way to add them to all projects if I don't use scripts. Removing people who left the business may be easier as I can remove the member from ACC.
Ideally it would be amazing if projects had an optional setting that allows permissions to change dynamically as I add/remove members from Companies. And that this setting can be in the template so all new projects are created the same way.
dvisani
I propose that AUTODESK implement the following functionality on the BIM360 system:
Provide a setting that allows anyone with a valid and active email login account, that has a pre-approved domain for the entire account (e.g., @MYCOMPANY.com), or as set by project (e.g., @INVITEDCONSULTANT.com) to be able to at a minimum see which projects are available to them. Then, if permissions are correctly set, they can self-add or self-select role, with option to send notifications to selected email account(s).
The default setting would be that it acts as it does currently (only invited can access a project),  An administrator could then determine to activate the "allow access by domain" on the entire account or by project, with permission options.
bessolo_bim_manager
bessolo_bim_manager
@lance.borst
Ideally, I need to be able to add a project to the user rather than users to the project. So if I could go to my user list and then select the user and see a list of all the projects they are in and be able to mass add them to projects based on their default role that would be SUPER helpful. Right now I have to go to each project and add them to each project one by one and it is very time-consuming.
Solution:
We have made a solution for this (Symetri's Naviate Cloud Manager that we have connected to ACC), until the platform hopefully can do it itself. Feel free to connect with me on Linkedin.
EricOlson1973
I, too, recognize a strong need for this.  It would be nice if we could define our company with individuals' email addresses and simply assign our entire company to a project rather than to individuals.
nvirkler
This should be solved by groups.  If you always want everyone in the estimating dept on every job, then add the "Estimating" group to the project template.  If it's a west side paving job, then manually add the "Westside Paving" group and everyone in that group gains access.  The beauty of this is when you hire someone working paving on the West side, you add them to the "Westside Paving Group" and in one step they instantly gain access to all Westside paving projects.
hworrell
@nvirkler - Is a groups a suggestion or something I've missed in the ACC/BIM360 setup?
nvirkler
@hworrell No, it's a feature request.  Every other software system/web portal I've ever used has groups to manage security/access across groups of people.  Autodesk Doc's is the only one I've seen where you can only administer access by manually adding users to projects.
hworrell
I was hopeful that I was missing something! Thanks for responding...
MichaelKullin
Managing members / access needs to be looked at critically by AutoDesk. One of the driving forces for implementing the use of ACC Docs is to allow collaboration by the correct people.
We must have a better way of managing access. It is not functional to need to add or remove members on an individual basis. We need to be able to do this as a Group type function. Alternatively one could look at building this functionality in to the Role function. Even adding by Company would help when adding people from outside of the host organisation.
BTW: I thought we used to be able to do this?
jonminick
Thanks for sharing your idea. Our Product teams are taking a look and will update a status here when we know more.
bessolo_bim_manager
Thank you, @jonminick adding users to the template to add them to all projects has been a hit or miss in terms of it working. This would be a very beneficial feature for a lot of us on the admin side of things.
