Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
ACC Model Coordination - Issue Filtering
In the ACC Model Coordination tool, a user is only able to filter the existing Issued by a drop-down showing only 2 options: "All Issues" or "Clash Issues".
In the Docs and Build tool, there is an expandable panel allowing the user to fine-tune the filtering of issues.
The Issues filtering panel of Build/Docs should be replicated in the Model Coordination tool
5 Comments
ahartke
This is a repost from the BIM 360 Ideas Board (recreated since it is an ACC issue).
Original Post:  https://forums.autodesk.com/t5/bim-360-ideas/model-coordination-issues-filter/idi-p/12204821
hnauDMCXY
Our site has thousands of issues we have to sort through all day! This would be super helpful to not need a separate tab with Docs/Build open just so we can see the issues filtered.
allan.stableford
Totally agree. Currently, I have to have a separate window open with Docs issues, just so that I can filter, find the issue number, then reference back to MC. This should have been improved a long time ago.
User interface needs to become consistent to each area of the platform.
jhijlkema
I've noticed the same thing. Weird that it does show up in Build and not in Model coordination.
When you use the Navisworks ACC Coordination add-in, you can filter your issues there, if that's any help.
Susana_Duarte_LMSI
This is now more or less impemented, I think. Problem is search tool is still lacking because it only search the title information... We still need better filtering tools that can use custom parameters.
Vote for this ones (an there are many more out there:
ISSUES Search in all the infos - Autodesk Community
Search and Sort Function for Custom Fields in Assets and Issues - Autodesk Community
Organizing Issues - Autodesk Community
