After the latest update, the terrain's BaseURN disappeared. In the properties, the BaseURN parameter is now null. Has this parameter been moved somewhere? How can I get the BaseURN now?
Solved by hallvard.braatenE6H3T. Go to Solution.
Hello! There has not been any changes to this behavior as far as I can tell. BaseURN is only set on the terrain if there has been done modifications on the terrain. If no modifications has been done, the baseURN is null. Is this not what you experience?
- Hallvard
Indeed. Very strange) I worked with this function for more then month and it seemed to me that it always returns BaseURN) Thank you very much
