I created a Line Based building, then I created floor plans. Then after that I needed to edit the sketch line of the building. Here I can add more nodes to edit the building line, but I can't delete nodes.
Actually, after closing the app and getting back, now it is working.
Any suggestion to avoid this thing happen?
Solved by marthe.brondbo. Go to Solution.
@gcruzM8N8G apologies for missing this one!
Did you manage to figure this out? It may be a better suited in our user forum, let me know if I should move and you can get help there instead.
Update: Sounds like you did solve the issue by closing the app and getting back, so marking this as solved unless I get other information!
