Help with Step 4 in Getting Started tutorial
ealexand5AMP6
ealexand5AMP6
Hello!
I am trying to follow the instructions on https://aps.autodesk.com/en/docs/forma/v1/overview/getting-started/
In step 4, I have pasted the code into Visual Studio Code (VSC) and saved the file locally as index.html
I then try in the VSC command line to paste the next line of code provided (http://localhost:5173/) but it gives me errors. Also, when I load the extension, the Hello World message pops up but then below that it says "localhost refused to connect."
Any help would be much appreciated!
henrik_steenJL382
Hello!
Can you share the errors you are experiencing?
It sounds like you are not properly running the local development server, so you can't access your project at http://localhost:5173/
Henrik
ilker.karadag
I have also confronted with the same error. You need to install or update node.js (https://nodejs.org/en). You can check your current version by typing node -v in the command line. Moreover you may need to install npm install -g http-server
If you are not familiar with this, just use simple web server software (https://simplewebserver.org/) which avoids local host refused to connect error.
marthe.brondbo
@ealexand5AMP6 Did you figure this our using @ilker.karadag suggestion? Checking that as the accepted solution - let us know if you need another fix!
Marthe
