I am writing an embedded view addin for Forma. I need to get the following data for each floor
- the surface of the floor
- the height of the floor
- the fontage linear of the floor
What is the methods to get this data from the selectedPath or selected element ?
Many thanks in advance,
Benoit
Solved by havard.hoiby. Go to Solution.
Hi Benoit. Cool to hear that you're writing an extension 🙂
There are two representations that you can look at for this. The grossFloorAreaPolygon and the experimental volume25DCollection.
When you use these representation APIs then you need to apply transforms to the geometry as described here. We also have a geometry api and an experimental version for the volume25DCollection where the transform is already applied.
Please let me know if you are not able to solve your case with these apis 🙂
- Håvard
Hello Havard,
Many thanks for your answer, I will try your solution and let you know!
