- Mute
- Permalink
- Report
[ FlexSim 21.0.4 ]
[Question]
I am creating a Process Flow that specifies the rack address in the global table, creates items in order, and picks the created items.
I created a parameter called "Destination" in <Assign Labels> and used Storage.system.getSlot to assign the path of the rack that created the item.
After that, I'm trying to get information about the object (in this case the Rack) that picks the item.
However, "Destination" becomes <no path>, and the object that created the item becomes NULL.
[Version]
FlexSim 21.0.4
[OS]
Windows 10 Pro (x64) 20H2
OS build 19042.870
[Phenomenon]
Please Check "TrainingProcessFlow.fsm" and "GetSlotError.xlsx" with the error image pasted.
When you execute <Step> several times in "TrainingProcessFlow.fsm", an exception occurs.
This message is probably caused by the "Rack" parameter being NULL.
When you click on the created token, "Destination" is <no path>.
