listen Events and Execute custom code by code
565109852
565109852
[ FlexSim 21.0.2 ]
How to listen to Object binded but not added trigger through code (NOT PF)? For example, When the item entering in Queue1, I want to execute the variable code (queueOnEntry) of Plane1.
I added an eventListener ,but it does not worked.
Any suggestion is welcome.
listen Events and Execute custom codeV21.0.2.fsm
Prompt reply. @jason.lightfoot @steven.hamoen @Matthew Gillespie @Ben Wilson
I know that message triggering can be realized, and so can PF. It's just that I'm doing a function development. Should I consider triggers function overload and how to implement it?
Be grateful.
joerg_vogel_HsH
then try the SDK
Can the function eventlisten be implemented? It seems that the third parameter of this function named relaynode is not executed.
It Worked.
philboboADSK
The problem with your model is that your plane reference is wrong. You are trying to reference "Plane24", but the object in your model is "Plane1".
Also, your queueOnEntry node needs to be toggled as FlexScript. Right now, it is just holding a string. Since you want it to be executed, you need to toggle it as FlexScript.
Attached is your example, modified to show you how the eventlisten() command works.
listen-events-and-execute-custom-codev2102_1.fsm
Phil BoBo
Sr. Manager, Software Development
The Object name was not changed back when uploading. The main problem is the node data type.Thank you very much.
