Errors encountered when importing DWG files and generating factory objects
s1101317F4S78
Message 1 of 9
s1101317F4S78
Hello everyone, I'm using the 2027 version. I'm encountering a problem during modeling: my factory assets are not generating correctly (as shown in the image below, there's an error), and I can't import the ER_small dwg solution file. FlexSim crashes every time I try to import it. Are some files or modules missing? Or is there another solution? Thank you.
Replies (8)
Message 2 of 9
vachaMLASK
Observer
Observer
something simillar happens to me. Every time I want to import dwg layout to Model Background, FlexSim crashes. I tried resaved dwg but it does not helped. Does anybody have solution?
Thanks in advance
Message 3 of 9
joerg_vogel_HsH
Have you tried to import an exported dwg in an older version?
Message 4 of 9
vachaMLASK
Observer
Observer
Yes, I tried dwg 2018, 2013, 2010, 2007, 2004 and 2000 and nothing changed. It only happends with larger dwg models. In the json error file is written:
"runtime_arch": 1,
"use_exception_trace": false
Message 5 of 9
s1101317F4S78
(view in My Videos)
This is the situation I encountered.
Message 6 of 9
vachaMLASK
Observer
Observer
Yes, that is it. Does anybody have solution?  I would be really gratful for it.
Message 7 of 9
joerg_vogel_HsH
Message 8 of 9
s1155449T7SAZ
New Member
New Member
same problem here, by the way I also YZU IEM student
Message 9 of 9
s1101317F4S78
Hello, I have downloaded both files, but the problem persists.
