Database - export data
Urvi_Sukharamwala
Urvi_Sukharamwala
[ FlexSim 24.0.1 ]
1706543226974.pngI have this example model can you please help me with exporting data on run stop trigger. What should be the flexscript?
jason_lightfootVL7B4
You can either trigger the export of all defined exports like this:
Object dbConnector=Model.find("Tools/DatabaseConnectors/DatabaseConnector1");
function_s(dbConnector,"exportAll");
Or trigger a single export:
treenode dbexport=variables(dbConnector).subnodes["exporters"].first;   // the first in the list of exports.
function_s(dbConnector,"exportSingle",dbexport);
Since it uses function_s calls, you may need to revise this code in the future, so if you need to invoke it in many places I'd place it in a user command and call that from multiple places instead.
Urvi_Sukharamwala
Thank you for the answer. Can you please explain how we can create subnodes (like exporters) as you mentioned for the script?
They get created by the Database Connector GUI when you set up the export. Are you saying you need to programatically add export definitions?
Urvi_Sukharamwala
Ok got it. Yes, if you can tell me how to do programmatically as well it would be great help
That's not going to be easy if you want to validate the table and column names against the target database. The basic function to add a global table to the export will start with
function_s(dbConnector,"createExporter",ownerobject(Table("GlobalTableName"));
The added sdt node will then need its subnodes set for:
1) the export table name in the DB
2) whether to append records
3) the mapping of column names between the tables
