[ FlexSim 24.0.1 ]
I have a isue when using a Math function (I have tested with Math.trunc and Math.floor) in a CalculatedTable.
When I use these functions, the model works without any issues. However, if I save this version of the model (control + s), the CalculatedTable does not function correctly and appears as a single row. If I remove the Math.trunc function, update it, and then add it back, the table functions correctly again.
If I close FlexSim and then reopen the saved model, the issue is resolved.
I have attached a dummy model for reference.
I have not been able to test this issue on version 23.0, but given that it also occurs on version 23.1, it is likely that the bug is present in both versions.
Thak you!
