Webroot av software just deleted a bunch of FC 2017 files from my system!
jeff.brower
jeff.brower
Wow, was in the middle of programming and FC 2017 just went away... disappeared from the screen. Webroot removed a bunch of FC files, not all of them but a bunch of them, working with IT now to see if webroot will put them back. It happened to both our systems, this blows. Heads-up out there!
Edit: had to reinstall FC and white-list the Autodesk folders...
kamalrajcv
Hi @jeff.brower
I am looking at the unanswered forum posts.
You may have found a solution to the issue by now, but since this can help the others, I wanted make a reply.
Does Webroot still remove a bunch of FC files from the system?
Kamalraj C V
Technical Support Specialist
jeff.brower
At that time we disabled Webroot and since then have moved to another av solution so we don't know if it still removes FC files. I suspect by now this would be resolved and would no longer be an issue.
