Wow, was in the middle of programming and FC 2017 just went away... disappeared from the screen. Webroot removed a bunch of FC files, not all of them but a bunch of them, working with IT now to see if webroot will put them back. It happened to both our systems, this blows. Heads-up out there!
Edit: had to reinstall FC and white-list the Autodesk folders...
Hi @jeff.brower
I am looking at the unanswered forum posts.
You may have found a solution to the issue by now, but since this can help the others, I wanted make a reply.
Does Webroot still remove a bunch of FC files from the system?
At that time we disabled Webroot and since then have moved to another av solution so we don't know if it still removes FC files. I suspect by now this would be resolved and would no longer be an issue.
