3d chamfer help how to chamfer at an angle?
rfuentes
rfuentes
i am trying to program a chamfer at a b53.00 angle but it is not coming out right any help would be appreciated.
jeff.brower
We usually make a setup for each angle that we need to do work on the part. So we'd probably make a setup at B53.00 and do the face, hole, and chamfer cuts while there
I can't see what type of file it is.  If it's milling, a new setup would work.  If it's turnmill, you can set the B Angle in the Tool Axis tab.
rfuentes
thank you for the replies, it is a mill set up rotary . i did do a new set up at a0b53.00, got the hole and boss to work but got stuck on the correct way to do the chamfer. any help would be appreciated thank you.
rfuentes
i tried doing a chamfer from curve and it did not work. tried doing  from surface-surface milling  got it looking better but my Z is always way off
