FeatureCAM Forum
Welcome to Autodesk’s FeatureCAM Forums. Share your knowledge, ask questions, and explore popular FeatureCAM topics.
simulation speed
4 REPLIES 4
ddube25
1005 Views, 4 Replies
simulation speed
is there a way to adjust the speed bar for the simulation. speed is either super slow or mach 3
4 REPLIES 4
ChristopherMarion
in reply to: ddube25
Hi @ddube25
Unfortunately there is no way to fine tune the simulation speeds like in previous versions (pre 2017).
The only way I have been able to do this is to use the ALT + Arrow keys on the keyboard.  To do this, before you run simulation, hold the ALT button down and then press and hold the right arrow to move forward.  You can also tap the right arrow to step the simulation forward.
The left arrow will move in reverse.
Hope this helps a bit.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
derik_ackermann
Yes this is horrible. Simulation running way to fast. The only way is the ALT →
Wish they would give us the freedom as in previous versions
Muppett1
I'm currently running 2020.3xxxx and I still have the slide bar adjustment for my simulation speed.  When did this go away?
bmarkeyJ44PH
I'm running current 2024 but that slider is pointless. It adjusts from really fast to super fast.
Technology Administrators
