ChristopherMarion
en respuesta a: ddube25
Hi @ddube25
Unfortunately there is no way to fine tune the simulation speeds like in previous versions (pre 2017).
The only way I have been able to do this is to use the ALT + Arrow keys on the keyboard.  To do this, before you run simulation, hold the ALT button down and then press and hold the right arrow to move forward.  You can also tap the right arrow to step the simulation forward.
The left arrow will move in reverse.
Hope this helps a bit.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
