Hey Semert,
This is my powershell script I use and it works perfect its installing as system.....
#* Declare Global Variables
$scriptpath = $MyInvocation.MyCommand.Path
$Scriptdir = Split-Path $scriptpath
#* Start logging transcript Fusion 360
If (Test-path "C:\Windows\DeakinDesktop\Logs\"){
Start-Transcript -Path "C:\Windows\DeakinDesktop\Logs\Fusion360-2021.log" -Verbose -Append -ErrorAction SilentlyContinue
#* Autodesk Fusion 360 Install
write-output "Fusion 360 Update"
& "$Scriptdir\FusionAdminInstall.exe" --globalinstall --quiet | write-output -ErrorAction SilentlyContinue
Start-Sleep -s 30
#* Copy Updater for Fusion 360
write-output "Copy Fusion 360 Updater"
get-date -DisplayHint Time | write-output
copy-item "$Scriptdir\update.ico" "C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d" -force | write-output -ErrorAction SilentlyContinue
copy-item "$Scriptdir\FusionAdminInstall.exe" "C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d" -force | write-output -ErrorAction SilentlyContinue
Start-Sleep -s 20
#* Remove Desktop Icons
Remove-Item "C:\Users\Public\Desktop\Autodesk Fusion 360.lnk" -force -erroraction silentlycontinue
#* Copy Shortcuts
If (!(Test-path "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk")){
New-Item -Path "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk" -ItemType directory -ErrorAction SilentlyContinue
copy-item "$Scriptdir\ShortCuts\*.lnk" "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk\" -force | write-output -ErrorAction SilentlyContinue
# Finish logging transcript
Stop-Transcript -ErrorAction SilentlyContinue
This works perfectly every time.. Let us know how you get on!
