Fusion Lab Installer Not Completing (Fusion Admin Install.exe)
EduITAdm
Message 1 of 54
EduITAdm
I am having difficulty getting the Fusion admin installer to complete.
I can see that it starts, then fires up the streamer. C:\Program Files\Autodesk\webdeploy gets created, and the production folder fills with the latest version of fusion. However, the desktop icon appears and then disappears. Even though it seems to be installed, it cannot be launched because the fusionlauncher.exe.ini file contains: "This is a place-holder file which is intended to be updated by the streamer."
So it seems like the install tanks right at the end. I am unable to locate a log file generated by Fusion Admin Install.exe.
This installer is running via the system account, so I would expect the log file to appear in c:\windows\temp but I am not finding it there.
Any clues on where I should be looking for that?
[EDIT] Found it at C:\Windows\System32\config\systemprofile\AppData\Local\Autodesk
Attached to post
Replies (53)
Message 41 of 54
SDNB
Interesting. I guess we'll see if it's fixed in Monday's release.
Message 42 of 54
its-desktop
Has the new version been released yet??
cheers
Craig
Message 43 of 54
SDNB
It was released last night. Confirmed this is fixed in the new release.
Message 44 of 54
SDNB
Confirmed this is fixed in yesterday's release.
Message 45 of 54
helpdesk
Hey - am I doing this right?
I grab the latest fusion admin install that I can find online
Ran the installer - and my version shows I am on
2.0.18961 x86_64 which is the march update
From my understanding this is the latest version that is supposed to fix it - v.2.0.19204
However when I try to kick it manually via powershell - C:\Program Files\Autodesk\webdeploy\meta\streamer\20240201094011> .\streamer.exe --globalinstall --process update
and i look at the logs in C:\Users\*user*\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
it says that  App(73e72ada57b7480280f7a6f4a289729f) is already installed, skip updating.
However that GUID points to 2.0.18961
Currently installed version for app 73e72ada57b7480280f7a6f4a289729f is 2.0.18961(20240417204129)
Would appreciate any insight please
Message 46 of 54
its-desktop
Hey Semert,
This is my powershell script I use and it works perfect its installing as system.....
#* Declare Global Variables
$scriptpath = $MyInvocation.MyCommand.Path
$Scriptdir = Split-Path $scriptpath
#* Start logging transcript Fusion 360
If (Test-path "C:\Windows\DeakinDesktop\Logs\"){
Start-Transcript -Path "C:\Windows\DeakinDesktop\Logs\Fusion360-2021.log" -Verbose -Append -ErrorAction SilentlyContinue
#* Autodesk Fusion 360 Install
write-output "Fusion 360 Update"
& "$Scriptdir\FusionAdminInstall.exe" --globalinstall --quiet | write-output -ErrorAction SilentlyContinue
Start-Sleep -s 30
#* Copy Updater for Fusion 360
write-output "Copy Fusion 360 Updater"
get-date -DisplayHint Time | write-output
copy-item "$Scriptdir\update.ico" "C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d" -force | write-output -ErrorAction SilentlyContinue
copy-item "$Scriptdir\FusionAdminInstall.exe" "C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d" -force | write-output -ErrorAction SilentlyContinue
Start-Sleep -s 20
#* Remove Desktop Icons
Remove-Item "C:\Users\Public\Desktop\Autodesk Fusion 360.lnk" -force -erroraction silentlycontinue
#* Copy Shortcuts
If (!(Test-path "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk")){
New-Item -Path "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk" -ItemType directory -ErrorAction SilentlyContinue
copy-item "$Scriptdir\ShortCuts\*.lnk" "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk\" -force | write-output -ErrorAction SilentlyContinue
# Finish logging transcript
Stop-Transcript -ErrorAction SilentlyContinue
This works perfectly every time.. Let us know how you get on!
Message 47 of 54
ifte_steinmann
It does not look like it's fixed to me.
I just tried the update. Uninstall did not work. Might be the old installer. No problem, I can remove the old folders later.
Unfortunately running "...\FusionAdminInstall.exe" --globalinstall --quiet" on a system level did not work either. I had no time to start debugging today.
Running the same command as an Admin when logged in works. So I will just do the update manually again. It's the quicker way for me today.
Would be interesting if others still have the same problem.
Edit:
It finally worked for me too. Downloading the installer again was the solution in my case. Between the initial update mail and my second download, the installer was changed from version 2.0.18961 to 2.0.19... something. Its working now.
Message 48 of 54
luket8ENCG
It isn't working for me either. When run manually from command prompt I still see the same error.
Message 49 of 54
its-desktop
You have to download the latest version here..
https://dl.appstreaming.autodesk.com/production/installers/Fusion%20Admin%20Install.exe
Its fixed in this version
cheers
Craig
Message 50 of 54
luket8ENCG
I have downloaded the latest version but still seeing the same issue.
Message 51 of 54
ajones4
Community Visitor
Community Visitor
@ifte_steinmann  & @luket8ENCG
It seems to be working for me now.
These are the final lines in the autodesk.webdeploy.streamer.log that should show up in the path C:\Windows\System32\config\systemprofile\AppData\Local\Autodesk  What is your log showing??
2024-05-17 11:38:14,675 - MainProcess(7900) - MainThread - adsk.dls.streamer.process.process - INFO :: Configure app complete Deploy to 2.0.19207 for app 73e72ada57b7480280f7a6f4a289729f
2024-05-17 11:38:14,691 - MainProcess(7900) - MainThread - adsk.dls.streamer.process.process - INFO :: Process Complete in 357.48448 seconds
2024-05-17 11:38:17,083 - MainProcess(7900) - MainThread - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2024-05-17 11:38:17,099 - MainProcess(7900) - MainThread - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2024-05-17 11:38:17,099 - MainProcess(7900) - MainThread - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2024-05-17 11:38:17,099 - MainProcess(7900) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-05-17 11:38:17,099 - MainProcess(7900) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x00000184A1C39350> #
2024-05-17 11:38:17,099 - MainProcess(7900) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
Message 52 of 54
luket8ENCG
It is not working for devices that had already tried to run the broken installer previously. I reimaged a computer and it installs fine.
Message 53 of 54
it_btull
It seems to be working, albeit as slow as molasses. We use MECM to install Fusion on some of our lab desktops. I don't think it's fully recommended, but it does work. I wrote an "if" script to check for the existence of the main production folder, "6a0c96 . . ." If it's there, it runs the "--process update --quiet" command. If that folder doesn't exist, like after a reimage, it runs the "--quiet" command, just to install the program. With the new version, it did install, but has taken over an hour, and still going, to uninstall the old version. There are currently 58 items remaining in the old folder and was stuck at 101 for some time, as well.
--Edit--
About 30 minutes later and all old content has been uninstalled and there are only 2 folders left. Total install/uninstall time was about 1 hour and 20 minutes. Computer has an i7, 8GB of RAM, and an NVMe.
Message 54 of 54
perdueb
Observer
Observer
Is there now a newer version than the one linked here?
If so, where do we go to download it? My downloads page only shows the client downloader not the Admin install. Thanks!
