Solved by HelenChen-ElectronicsQA. Go to Solution.
Hi @Anonymous ,
It would seem that because that hole is considered part of a component it's not considered in that counter. @HelenChen-ElectronicsQA Could you make a ticket for this? The dialog is confusing, maybe it should specify total holes and include the holes that are in components.
Let me know if there's anything else I can do for you.
Best Regards,
Hi @Anonymous ,
I hope you're doing well. Sorry for not clarifying, your board will be manufactured correctly when you send them the gerbers and drill files. The issue is strictly with the Board information dialog and how it counts holes.
Let me know if you need more clarification.
Best Regards,
Hi @jorge_garcia , @Anonymous ,
Sorry for any confusion. I will log a ticket to track it.
As a workaround, @Anonymous , you could go to Manufacturing > Board Tab > where you could see the drill information in your board.
Hope it helps.
Helen
Thanks for your replies @HelenChen-ElectronicsQA , @jorge_garcia …I already sent out the PCB for manufacturing and asked them to verify regarding the hole. I was able to see the hole on the different board layers though.
Hi @Anonymous ,
Thank you very much for feedback.
Hope all the best.
Please feel free to let us know if anything else you may need our assistant.
Helen
