SPICE DIGSRC model giving me problems
k7michal
k7michal
Hi everyone, thank you for your help.
I'm just getting started in SPICE modeling. Watched the 1H28m primer... played with analog and digital examples and I keep running into this issue which I've narrowed down to 1 particular model.
For some reason I can't get DIGSRC to work right.. so I made a separate .sch program with just that model and a voltage probe and after setting up the table and hitting simulate, it just time elapses on and on and on until there is a time out.
I hope that I'm just not doing something correctly.
Thank you.
* SpiceNetList
* Exported from DSCR_test.sch at 11/29/19 5:45 PM
* EAGLE Version 9.5.2 Copyright (c) 1988-2019 Autodesk, Inc.
.TEMP=25.0
* --------- .OPTIONS ---------
.OPTIONS ABSTOL=1e-12 GMIN=1e-12 PIVREL=1e-3 ITL1=100 ITL2=50 PIVTOL=1e-13 RELTOL=1e-3 VNTOL=1e-6 CHGTOL=1e-15 ITL4=10 METHOD=TRAP SRCSTEPS=0 TRTOL=7 NODE
* --------- .PARAMS ---------
* --------- devices ---------
X_X1 N_1 DRIVERD1_1
X_D1 N_1 DIG_N_1 DTOAB1
* --------- models ---------
* model file: Base: /Users/meehowkailan/Documents/EAGLE/projects/spice it up 1/DRIVERD1.mdl, DRIVERD1_1
* autodesk eagle - spice model file
.SUBCKT DRIVERD1_1 n1
a_source [n1] d_source1
.model d_source1 d_source (input_file="/Users/meehowkailan/Documents/EAGLE/projects/spice it up 1/driverd1_2.dsource.txt")
.ENDS DRIVERD1_1
* Autodesk EAGLE - SPICE Model File
.SUBCKT DTOAB1 D A
abridge [D] [A] dac_buff
.model dac_buff dac_bridge(out_low = 0.3 out_high = 2.5)
.ENDS DTOAB1
* --------- simulation ---------
.control
set filetype=ascii
TRAN 0.0003 0.06 0 0.0003
write DSCR_test.sch.sim V(DIG_N_1)
.endc
.END
 im having the same problem did you figure it out?
holger.vogt
There might be a problem with the ngspice dsource model used in the adder.sch: It will not accept a file path with spaces.
EAGLE installed in "EAGLE 9.6.2", the simulation of adder.sch does not work. Copying the folder "C:\EAGLE 9.6.2\examples\projects\examples\ngspice" to C:\EAGLE\ngspice and opening C:\EAGLE\ngspice\Digital\adder.sch in EAGLE, simulation is up and running.
I will care for this bug in ngspice.
holger.vogt
I have uploaded a fix to ngspice git branch pre-master.
The fix will be available in ngspice-35, to be released by end of July.
