Issue with Spice Simulation
boe15002
Message 1 of 1
boe15002
When adding a model to the AD623R (Default IC in Analog Devices library) and after mapping everything correctly (see attached image), I get this error during simulation:
Too few parameters for subcircuit type "ad623" (instance: xx_ic1)
Note: No ".plot", ".print", or ".fourier" lines; no simulations run
I've included the generated netlist (see text document), and discovered thanks to this post on the forum that the simulator is not connecting all of the nodes of the IC. The ad623 model requires 8 connections and the simulator is only connecting 2. I can go in and set up the netlist correctly manually and it runs just fine. Every time I restart the simulation however (after every minor change) the netlist is regenerated as well. I've been just keeping a copy of the correct implementation of the model in an editor off to the side so I can copy/past on every run, but needless to say it's not very practical. Not to mention, now I'm starting to add more ICs to the circuit, and they are having the same issue as well. It's just going to become a mess way too quickly. Any advice please?
Replies (0)
