Problems trying to run a 555 timer model
Hi
I've used ngspice successfully to do some basic modeling but I can't seem to figure out the error I'm getting when adding a 555 timer.
Circuit: * spicenetlist
Too few parameters for subcircuit type "ne555" (instance: xx_ic1)
Note: No ".plot", ".print", or ".fourier" lines; no simulations run
I've got a simple oscillator circuit that uses a 555 timer and I went out and found a couple of different SPICE models to try. Both the NE555 and TLC555 (below) give me the above error when attempting to simulate.
UPDATE: after fiddling with this some more, I realized the error seems to be as a result of not having one of the unused pins on the 555 attached. I grounded the unused pin 5 and now it seems to work. Is there a way around this?
Here's the complete netlist file. I get that there are no .plot or .print lines and thus no simulation is being run but I've never had to add these to the file before. They were always added for me. Even when I manually add them I seem to get the same error.
* SpiceNetList
* Exported from SpiceCodeTransmitter.sch at 3/29/20 2:55 PM
* EAGLE Version 9.6.0 Copyright (c) 1988-2020 Autodesk, Inc.
.TEMP=25.0
* --------- .OPTIONS ---------
.OPTIONS ABSTOL=1e-12 GMIN=1e-12 PIVREL=1e-3 ITL1=100 ITL2=50 PIVTOL=1e-13 RELTOL=1e-3 VNTOL=1e-6 CHGTOL=1e-15 ITL4=10 METHOD=TRAP SRCSTEPS=0 TRTOL=7 NODE
* --------- .PARAMS ---------
* --------- devices ---------
C_C2 N_1 0 .01uf
L_L3 N_7 N_3 7uh
X_IC1 0 N_1 N_5 N_3 NE555
R_R2 N_1 N_2 1k
C_C3 N_7 N_6 470pf
L_L4 N_3 N_6 7uh
Q_T1 N_6 N_4 N_5 2N2222
V_V1 N_3 0 5v
R_R3 N_4 N_3 100k
C_C1 N_3 0 .01uf
R_R4 N_5 0 100
C_C5 0 N_6 .005uf
R_R1 N_2 N_3 100k
C_C4 N_7 N_4 .1uf
* --------- models ---------
* Copyright © Linear Technology Corp. 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005, 2008. All rights reserved.
.subckt NE555 1 2 3 4 5 6 7 8
A1 N001 2 1 1 1 1 N003 1 SCHMITT Vt=0 Vh=1m
R1 N001 1 5K
R2 5 N001 5K
R3 8 5 5K
S1 1 7 N007 1 D
A2 N011 N003 1 1 1 1 N008 1 SRFLOP Trise=100n tripdt=10n
A3 6 5 1 1 1 1 N012 1 SCHMITT Vt=0 Vh=1m
S2 8 3 N009 1 O
S3 3 1 1 N009 O
A6 1 N006 1 N008 1 1 N007 1 OR Ref=.5 Vlow=-1 Trise=100n
R7 8 1 4K
R9 2 1 1G
R10 6 1 1G
A4 1 N008 1 N006 1 N009 1 1 OR ref=.5 Vlow=-1 Trise=100n
A5 4 1 1 1 1 N006 1 1 SCHMITT Vt=.7 Vh=1m
D1 4 1 DR
A7 1 N006 1 N012 1 1 N011 1 OR
D2 8 4 400uA
.model DR D(Ron=150K Roff=1T Vfwd=1.6)
.model O SW(Ron=6 Roff=1Meg Vt=0 Vh=-.8)
.model D SW(Ron=6 Roff=.75G Vt=.5 Vh=-.4)
.model 400uA D(Ron=1K Ilimit=400u epsilon=.5)
.ends NE555
* From Texas Intruments
* TLC555 TIMER MACROMODEL *
* 4/1/92 *
.SUBCKT TLC555 1 2 3 4 5 6 7 8
* Node Connection
* COMMON
* | TRIGGER
* | | OUTPUT
* | | | RESET
* | | | | CONTROL
* | | | | | THRESHOLD
* | | | | | | DISCHARGE
* | | | | | | | VDD
* 1 2 3 4 5 6 7 8
EREF 15 1 8 1 .5
GSOURCE 8 3 8 26 12.5E-3
GSINK 3 1 26 1 67E-3
VD1 8 27 DC .8
VD2 28 1 DC .85
VREF 30 1 DC 1.2
C1 29 1 700E-15
RREF2 30 1 100E3
RREF 15 1 100E3
ROUT 3 1 100K
R1 6 1 500E9
R2 2 1 500E9
R3 8 5 75E3
R4 5 9 75E3
R5 9 1 75E3
R6 10 11 1E3
R7 13 14 1E3
R8 8 12 150E3
R9 4 8 500E9
R10 20 19 1E3
R11 16 17 1E3
R12 8 18 150E3
R13 8 21 150E3
R14 22 23 1E3
R15 8 26 150E3
R16 24 25 1E3
R19 7 1 500E9
R20 29 26 1E6
D1 1 11 DMOD
D2 12 11 DMOD
D3 12 14 DMOD
D4 1 14 DMOD
D5 18 17 DMOD
D6 1 17 DMOD
D7 18 19 DMOD
D8 1 19 DMOD
D9 21 14 DMOD
D10 21 25 DMOD
D11 1 23 DMOD
D12 18 23 DMOD
D13 26 25 DMOD
D14 1 25 DMOD1
D15 3 27 DMOD
D16 28 3 DMOD
E1 10 1 6 5 1000
E2 13 1 2 9 1000
E3 16 1 15 12 1000
E4 22 1 15 21 1000
E5 24 1 15 18 1000
E7 20 1 4 30 1000
M1 7 29 1 1 MOSMOD
.MODEL MOSMOD NMOS (LEVEL=1 KP=1 VTO=1 RD=5)
.MODEL DMOD D (RS=1E-6)
.MODEL DMOD1 D (RS=1E-6 IS=1E-9)
.ENDS
.MODEL 2N2222 NPN (IS=3.88184e-14 NF=0.90 BF=240 VAF=114
+ IKF=0.293 ISE=2.73p NE=2.00 BR=4.00 NR=1.00
+ VAR=24.0 IKR=0.600 RE=0.194 RB=0.777 RC=0.5
+ XTB=1.5 CJE=24.9p VJE=1.10 MJE=0.500 CJC=12.4p VJC=0.300
+ MJC=0.300 TF=371p TR=64.0n EG=1.12 )
* --------- simulation ---------
.control
set filetype=ascii
OP
write SpiceCodeTransmitter.sch.sim
.endc
.END
