Protoboard pattern
Protoboard pattern
Protoboard pattern
I am still looking for a solution how to implement protoboard pattern
The main problem is how to lock it in position so I can move the components around without moving the part of the pattern  too.
I did try SMD "test pad" on bottom layer.
There are two issues with  that approach.
Both related to how to lock / unlock a group.
Locking each pad in 8x8x3 pattern is tedious!
Second issue is - when I build "locked design block" it cannot be rotated  into position - only moved into a position where it became locked.
Since I need both orientation of the 8x3 pattern the hack is to build two blocks.
jorge_garcia
Hello @Anonymous,
I hope you're doing well. What would make this work perfectly would be the concept of a persistent group (we are working on this as we speak) where you could preserve the group definition past the initial selection. For now what I would go with the designblock route, make a few variations of the protoboard pattern and then build up the shape you need from a few blocks.
Don't lock components when forming the designblock you don't gain too much from doing that. Once everything is placed on your design then you can do a group lock and group unlock.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
"group lock and group unlock."
How?
I presume no GUI for that, so can  you give me a hint using CLI ?
Partially solved by combination of layers.
jorge_garcia
Hi @Anonymous,
There is a GUI for that! Here's the procedure:
1) From the GROUP
2) Click on the Lock
3) ctrl+right click a part within the group
If you want to ungroup it's ctrl+shift+right click
Let me know if you continue to run into issues.
Best Regards,
Jorge Garcia
