Protoboard pattern
11:10 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am still looking for a solution how to implement protoboard pattern
The main problem is how to lock it in position so I can move the components around without moving the part of the pattern too.
I did try SMD "test pad" on bottom layer.
There are two issues with that approach.
Both related to how to lock / unlock a group.
Locking each pad in 8x8x3 pattern is tedious!
Second issue is - when I build "locked design block" it cannot be rotated into position - only moved into a position where it became locked.
Since I need both orientation of the 8x3 pattern the hack is to build two blocks.
