EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Design rule error unexplained
2 REPLIES 2
309 Views, 2 Replies
I get a clearance error and I cannot find the cause for this error.
The clearance is 0.2mm and the DRC allows 0.15mm. Why is there an error reported?
I have attached the screendumps
2 REPLIES 2
one-of-the-robs
The screenshot looks like you only get this on a few pads, yes? One common cause of this is if the nets associated with those pads have a non-default net class that defines larger clearance requirements.
That said, you're using a non-standard palette which confuses me a little as to what's what. The highlights (which I assume are the DRC markers) are a slightly odd shape. It also looks like perhaps there are some layers that are hidden? Worth a look on them.
in reply to: one-of-the-robs
Thanks a lot. It was indeed a netclass that was applied to some nets. I don 't know how that could happen because I did not assign a net class to those nets.
But anyway, Problem is solved.
Technology Administrators
