EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Critical bug in DRC rule for "Minimum Drill" size
4 REPLIES 4
chipdesk
984 Views, 4 Replies
I changed the Minimum Drill size from 0.35mm to 0.15mm in the DRC rules of my project:
pic01.pngUnfortunately, this has absolutely no effect on my board. I clicked both the Apply and then Check buttons in the DRC window, but Eagle keeps indicating all drills with a diameter below 0.35mm as an error.
The error is indicated to be on layer 20 (the Dimension layer):
I use the latest Eagle version: 9.5.1 Premium
4 REPLIES 4
in reply to: chipdesk
This sounds similar to the infamous Airwire bug that has been mentioned before. I'd recommend closing then re-opening your file. This method works for the Airwire bug so it would be interesting to see if it applies to this drill size bug too.
chipdesk
Negative,
Closing Eagle and restarting the project has no effect.
jorge_garcia
Hello @chipdesk,
I hope you're doing well. Whenever this happens almost always there's a conflict with the netclasses. Check your netclasses and make sure the default netclass is set to 0 for all of it's values. If it's set to anything but 0 then it's possible for these settings to override the DRC.
Let me know if you continue to run into issues.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
chipdesk
in reply to: jorge_garcia
Hi @jorge_garcia ,
Thank you so much for fixing the problem! It was indeed due to net classes. I completely forgot about them.
If I may give some feedback: there is already some useful info written at the bottom of each DRC tab. Perhaps you could add a warning there, like
 > "Warning: DRC rules can be overridden by net class rules. Click here to check your netclass rules."
That would have saved me (and other users) a lot of headaches 😉
Kind greetings,
Kristof Mulier
