I changed the Minimum Drill size from 0.35mm to 0.15mm in the DRC rules of my project:
Unfortunately, this has absolutely no effect on my board. I clicked both the Apply and then Check buttons in the DRC window, but Eagle keeps indicating all drills with a diameter below 0.35mm as an error.
The error is indicated to be on layer 20 (the Dimension layer):
I use the latest Eagle version: 9.5.1 Premium
Solved by jorge_garcia. Go to Solution.
This sounds similar to the infamous Airwire bug that has been mentioned before. I'd recommend closing then re-opening your file. This method works for the Airwire bug so it would be interesting to see if it applies to this drill size bug too.
Hi @jorge_garcia ,
Thank you so much for fixing the problem! It was indeed due to net classes. I completely forgot about them.
If I may give some feedback: there is already some useful info written at the bottom of each DRC tab. Perhaps you could add a warning there, like
> "Warning: DRC rules can be overridden by net class rules. Click here to check your netclass rules."
That would have saved me (and other users) a lot of headaches 😉
Kind greetings,
Kristof Mulier
