EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Connect Single Pin With Multiple Pads
5 REPLIES 5
eirij
3014 Views, 5 Replies
Could you please tell me, how can I use the command "CONNECT" to join a single pin with multiple pads?
Thanks!
Best Regards,
Muhammad Eirij
5 REPLIES 5
rachaelATWH4
in reply to: eirij
You specify the pad numbers in single quotes separated by spaces. Here is an example:
CONNECT G$1.DVCC 'C1 C3 D4 E4 E5';
The above connects the DVCC pin of the symbol named G$1 to pins C1, C3, D4, E4, and E5 of a BGA package.
Best Regards,
Rachael
eirij
in reply to: rachaelATWH4
Thanks Rachael.
Best Regards,
Muhammad Eirij
rachaelATWH4
in reply to: eirij
You're welcome Smiley Happy
lsi8PXFWR
in reply to: eirij
i followed these instruction in Fusion Electronics so i was expecting to be able to connect any of the pads I wanted but they are behaving as 4 separate pads in layout. Shouldn't I be able to pass a wire from pad B "through" any of the other B1, B2, or B3 if I appended them all to the GND pin using that "connect" command?
jorge_garcia
in reply to: eirij
Hello @lsi8PXFWR,
I hope this message finds you well. This thread is pretty old so things have improved since then. Just from the picture it looks like the component is not correctly defined. In the library editor you have to tie those 4 pads to a single pin in the schematic. See this video for more info
https://www.youtube.com/watch?v=2GVqwGs8qc8&list=PLmA_xUT-8UlKE-U-eEqrkNEI7rd1fUnLY&index=5
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
In the final video of this series we combine all of the assets we made in previous videos of this series to make device we can use in our electronics schematics. Video 1: Electronics Libraries Overview https://youtu.be/xNIEXCimRSg Video 2: Making Schematic Symbol https://youtu.be/-LWLXkMUcbk Video
