- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
First time posting, long time stalking.
I'm attempting to create a block with 3 different views of a helping hand bracket (elevation, plan & section), with a separate view for the rail elevation/length.
This issue I have is as follows: the helping hand bracket ranges from 65mm depth with a 60mm punched tab to 80-240mm depth with a 70mm punched tab, along with different cavity depths for the rails; 80-105mm for 65mm bracket, and 88-120mm for the 80mm bracket, increasing by 20mm each time until the 240mm bracket is 248-280mm. There will also be different rail configurations (on plan only), a 60x40mm L-rail, 100x60mm, 125x60mm & 125x40mm T-rail. My main gripe at the moment is trying to get a view of each bracket increment, along with a locked off cavity depth value for each.
This is a link to the system, which shows the bracket sizes/cavity depths. https://www.plastestrip.com/product-category/fastframe/helping-hand-systems/rivet-face-fix/
The block i've posted has all the information for the plan in the lookup table but still seems to be "read only".
I'm relatively new to using the lookup parameter so I'm positive I've done something incorrectly down the line, but if anybody has any advice then it would be much appreciated.
Damian
