01:15 AM
For my Type SP grating side view dynamic block i have a issue with the array of 2 different objects,
I want to have it when you increase the length of the grating by 1 step(20 mm), another row of 1 object, either the small one or the longer one, shifts to the correct position.
When you drag to extend the grating it doesn't correctly place the small object to its position, this only works when you shift it another step forward, when a longer one needs to be in the position.
Does this issue have to do with the distance between the arrays, or with the placement of the parameters?
Thank you for the help
