Axes on multiple scales do not center
andres_bonilla
andres_bonilla
Hi everyone!
I have a dynamic block for the axes, but I have not managed that when it has several scales assigned, the block continues in the same 'centered' position and not as shown in the attached image.
What block property should I adjust to solve this problem?
Thank you.
Libbya
I assume you are talking about and annotative block and how it behaves with changes to the annotative scale.  The block will always scale from the block base point or origin within the block if a base point parameter is not used.  Construct the block in a manner so that the origin within block editor is the location you would like the block to scale from. Post your block if you want further assistance.
andres_bonilla
Thank you for your answer,
in the vertical direction the block behaves as I require it, but when it is located in the horizontal direction it is when the problem arises.
Attached block for review.
vinodkl
Try adding a Basepoint parameter to the block in the center of the circle or else you could recreate the block with the center of the circle as basepoint to eradicate this issue.
And another tip. Use the command "SELECTIONANNODISPLAY" and set it to "0" to make the different scales set to the object not show up when you select the objects. It would be quite annoying while modifying the object🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Libbya
This might help.
andres_bonilla
Thank you very much for your excellent help, I really appreciate it!
